RoSu54
Jan 01, 2015Follower
AirCard 770s no battery error
Intermittently my AirCard 770s displays a no battery error. Removing the battery resets the AirCard and the AirCard works ok for 15 minutes then displays the no battery error again. The battery is fu...
pskzford
Aug 05, 2015Initiate
I was told that I would have to purchase a new device because mine was out of warranty and I was not eligible for an upgrade. I will not be renewing my service on this device in October. This is the second one to do this with me. Exact problems everyone else is saying.
docsdock
Aug 24, 2015Tutor
Just started have the no bat error so i went to att and they did a factory reset and said it should be fine but if not go to an att store and bu a new one -- I have had it a little over a year - shouldn't it last longer that that ????
