RoSu54
Jan 01, 2015Follower
AirCard 770s no battery error
Intermittently my AirCard 770s displays a no battery error. Removing the battery resets the AirCard and the AirCard works ok for 15 minutes then displays the no battery error again. The battery is fu...
MarkMcD
Sep 14, 2015Tutor
Remove the battery all together and just use plug in power supply at home/work or car. The read out will still stay 'No Battery' but it will work. If you must use battery consider buying a new unit or use warranty route if still avaliable. My unit is out of warranty and I paid cash for the D thing. I may dump AT&T for that reason. Good luck!
