RoSu54
Jan 01, 2015Follower
AirCard 770s no battery error
Intermittently my AirCard 770s displays a no battery error. Removing the battery resets the AirCard and the AirCard works ok for 15 minutes then displays the no battery error again. The battery is fu...
cathyr
Oct 12, 2015Tutor
Same problem, same time frame. What is this, planned obsolescence? Having this happen exactly one year into a two year plan is a PIA.
- MarkMcDOct 12, 2015Tutor
Curious, did you try removing the batteryband just use the power cord? Did it work for you? Mark
- Ken4321ROct 12, 2015Aspirant
I am another with the same issue. It appears mine works without the battery, at least for the last 10 minutes. Hasn't worked for 2 weeks with one trip to AT&T and suggested replacement.....
With just the power cord it works continously MOST of the time but every now and then it reboots itself and I have to reconnect. It is a little annoying but I can live with it for now. My guess is the issue will get worse over time. I am angry I will have to buy a new hotspot and have doubts about reliability. I wonder if a hacker was able to mess the device up through the Internet somehow. Good luck!
- cathyrOct 12, 2015Tutor
Mine's working without the battery, a better option than having to replace it right now. Thanks for the tip.
