LiCoO2-18650
Sep 28, 2016Follower
AirCard 779S (Sprint) – NETGEAR Fuse Mobile Hotspot
Hello, I have a quick and easy question:
If I need to replace the original rechargeable Li-Ion battery in my "NETGEAR Fuse Mobile Hotspot" device:
I need to know which of the 3 batteries that you carry will work the best in this device: (longest lasting, compatibility that will for sure work)
1). Nitecore 18650 3400mAh 3.7V Protected Lithium Ion
2). Olight 18650 3400mAh 3.6V Protected Lithium Ion
3). XTAR 18650 3400mAh 3.6V Protected Lithium Ion
ps. I need to make sure either of these 3 batteries will work (compatible) in the Netgear AC779S-Sprint Mobile Hotspot, simple as that! Thank you!
/S/ Chris
/S/ Chris
1 Reply
- DarrenMSr. NETGEAR Moderator
Hello Lico02
AC779S Sprint uses a W-8 battery. 3.8V and 2500mAh.
DarrenM
