dwaynemichnal
Jul 14, 2016Follower
Aircard 781s unite pro att hotspot
I bought this hot-spot online and they sent me a cheap Samsung charger with a tiny small wire that I'm not sure is what I need to charge it properly. What size charger do I need. I also did not get the boost charge cable. What exactly is this used for. I don't use a PC if that helps you with ur answer. If it's important to use can you tell me exactly what I need to look for when looking to purchase it. Thank u for all ur help
1 Reply
- DarrenMSr. NETGEAR Moderator
Hello dwaynemichnal
You will want to get a 5 volt 1 amp charger.
DarrenM
