Czaka49
Feb 19, 2019Aspirant
Aircard 781s unite pro att hotspot
Losing connection and bad bandwidth
shellywalrus
Same issue - keeps losing connection even with 4/5 bars every 15 minutes or less. Only resolution is restarting, which is annoying. *FRUSTRATED***
Blanca_O
Feb 26, 2019NETGEAR Employee Retired
Hi Czaka49 and shellywalrus
I suggest to check this link for tips and troubleshooting. Or, you can call AT&T for them to check the device.
Blanca
Community Team
