freddyuk
Feb 18, 2020Aspirant
Aircard 785 Dropping out
I have just bought an Aircard 785 and set it up easily. I have 2 bars signal to Gomo (Ireland) and when I first connected Macbook Pro the Aircard connected no problem. Tested using Youtube and it wor...
- Feb 26, 2020
I esolved the problem myself. I checked the APN settings which were showing "meteor" which is no longer active in Ireland as the serice is now run by EE so by checking and then changing the APN settings I had full internet service.
Hope this helps others
Blanca_O
Feb 23, 2020NETGEAR Employee Retired
Hi freddyuk
Welcome to NETGEAR Community!
Checking on the device LCD screen, please describe the hotspot's status.
Kindly reset the hotspot. Here's how:
1. Press the Power and Navigation buttons at the same time for five seconds.
2. Press the Navigation button to cycle to the Factory Reset screen.
3. To start the factory reset, press the Power button.
It takes about one minute to complete a factory reset.
4. After the device resets, reconnect WiFi devices.
Blanca
Community Team
- freddyukFeb 26, 2020Aspirant
