d4rr3ll
Aug 27, 2015Aspirant
AirCard 785 Retail unlocked . Firmware update FAILED! (part 2)
Follow on thread from https://community.netgear.com/t5/AirCard-LTE-Hotspots-Gateways/AirCard-785-Retail-unlocked-Firmware-update-FAILED/td-p/974257 DarrenM - I'll try contacting support and see ...
DarrenM
Aug 27, 2015Sr. NETGEAR Moderator
Hey d4rr3ll I sent ya a PM
DarrenM
- d4rr3llSep 10, 2015Aspirant
Hi,
So I raised a support ticket and haven't heard a thing back :(
Would you be able to chase DarrenM ?
Thanks
- DarrenMSep 10, 2015Sr. NETGEAR Moderator
Hello d4rr3ll
Im so sorry that no one has contacted you on the ticket I have made sure that it assigned to the proper support group and someone should be in contact with you now let me know if you have any more issues or concerns.
DarrenM
I just got a update about this issue that you may see when you go to update the firmware that it has failed but it may not have. If you try to check for updates again and it says your device is up to date then the firmware actually went threw. Another way to check if the firmware is up to date is go and try to change your admin password if it allows you to then it should be up to date the last firmware fixed the issue with changing the admin password. But if your still having issues let me know.
DarrenM
