Retired_Member's avatar
Retired_Member
Nov 17, 2019
AirCard 785S how to perform driver update using a PC under MacOS/also how to solve battery charging
Hi,   A couple of years ago I bought the Netgear 785S. I did use it for a year and it worked allright. Then I put it in a drawer and only yesterday picked it up again. I have bought a new SIM-car...
  • Retired_Member's avatar
    Retired_Member
    Nov 17, 2019
    Sorry guys,  RTFM
    Battery is probably corrupt;
    Updates have been installed, after connecting device to iPad the Netgear Mobile app recognized the device.
    So, SOLVED!
