msdclark
Jan 06, 2020Tutor
Aircard 785S Searching Cellular Signal & won't connect
I have a Netgear Aircard 785S that is unlocked (I think referred to as retail). I have used it in the past with an AT&T sim card in the US and in Europe with an Orange Sim card and had no issues. I pu...
Blanca_O
Jan 16, 2020NETGEAR Employee Retired
Hi msdclark
Welcome to NETGEAR Community!
You can configure your hotspot's Access Point Name (APN) though your hotspot is not working. Here's how to add a new APN to your hotspot:
- Launch a web browser from a computer or WiFi device that is connected to the network.
- Enter http://netgear.aircard or http://192.168.1.1. A login screen displays.
- Enter the password in the Sign In field. The default password is password. The password is case-sensitive
- Click the Sign In button
- Select Settings > Network > APN
- Enter a name for the APN
- Enter the APN. If you do not know the APN, contact your service provider
Blanca
Community Team
- JohnPengJan 16, 2020NETGEAR Expert
Please advise the device SKU name. You can find it printed on the label under the battery.
I can help to find out whether the device supports T-Mobile Bands.
Thanks
- msdclarkJan 20, 2020Tutor
The sku name is AC785-100EUS
Blanca,
Are you saying that I need to be connected to the network the Netgear is broadcasting? That is the issue. I cannot even get a cellular signal, so there is no network being broadcasted from the Netgear Aircard.
So http://netgear.aircard doesn't display a web page and I can't use http://192.168.1.1. because this IP Address is assigned to another network.
