rusty99
Aug 16, 2021Tutor
AirCard 785S wifi device connections
I use the AirCard on a remote property when I visit a few times a year. It works fine for web surfing etc but I can't connect non-web devices to it such as printing via WiFi or connecting a Google Ch...
- Aug 19, 2021Wi-fi bands? 2.4/5GHz, some devices only have 2.4GHz, my Philips Ambilight TV for instance only has 2.4Ghz as it’s considered the more stable for Wi-fi coverage.
https://www.actcorp.in/blog/difference-between-2.4ghz-and-5ghz-wifi
Are you in 5GHz only Wi-fi mode on the Aircard ? Because it defo won’t connect even if it can see them.
AyeAyeAye
Aug 19, 2021Apprentice
rusty99
Oct 01, 2021Tutor
Thanks - it turns out both devices, the printer and the original Chromecast only work on 2.4 mHz. I had both bands enabled on the modem but that obviously led to confusion for the devices.
