ordos18
May 13, 2018Tutor
AirCard 785S without battery
Hello!
I have a problem with turning on AC 785S without battery, only on AC power supply. I found similar topic where someone confirmed that it is working, but not in my device.
https://commu...
ArodiD
May 13, 2018NETGEAR Expert
Hi ordos18,
I recommend using a power adapter which is 5V 2A minimum. The supplied power adapter will not keep the device running without battery.
Kind Regards,
ArodiD
- ordos18May 13, 2018Tutor
ArodiD, thank you for your tip. I did try with 2,4A power supply, but with the same result. Maybe there is some current limiting because of USB autocoding, I will check it on another charger.
However, if 1A charger is sufficient for charging battery and running the network, it should work as well without charging the battery. Do you think that router needs more power during booting?
Thank you,
Maciek
- ordos18May 15, 2018Tutor
Still no success on other chargers. While running and charging a battery it takes 1A even when charger can supply more, so I don't think that it needs more current.
ArodiD, do you have any idea?
Thanks,
Maciej
- JasonNMay 16, 2018NETGEAR Employee Retired
Hi ordos18,
Thank you for responding to the post. I see that you have tried other chargers but did you try using a 5V 2A minimum charger as Arodi has suggested?
Please let me know. :]
- Jason N
