ordos18
May 13, 2018Tutor
AirCard 785S without battery
Hello!
I have a problem with turning on AC 785S without battery, only on AC power supply. I found similar topic where someone confirmed that it is working, but not in my device.
https://commu...
ordos18
May 13, 2018Tutor
ArodiD, thank you for your tip. I did try with 2,4A power supply, but with the same result. Maybe there is some current limiting because of USB autocoding, I will check it on another charger.
However, if 1A charger is sufficient for charging battery and running the network, it should work as well without charging the battery. Do you think that router needs more power during booting?
Thank you,
Maciek
ordos18
May 15, 2018Tutor
Still no success on other chargers. While running and charging a battery it takes 1A even when charger can supply more, so I don't think that it needs more current.
ArodiD, do you have any idea?
Thanks,
Maciej
- JasonNMay 16, 2018NETGEAR Employee Retired
Hi ordos18,
Thank you for responding to the post. I see that you have tried other chargers but did you try using a 5V 2A minimum charger as Arodi has suggested?
Please let me know. :]
- Jason N
- ordos18May 20, 2018Tutor
JasonN, yes I did. It was 2.4A 5V USB charger as I mentioned before. Maybe it doesn't work because of USB autocoding. What USB voltages at data pins does it need to run?
However I found a simple and easy solution (workaround?). I just put a small piece of adhesive tape inside the USB plug to insulate two pins in the middle: D+ and D-. After that it works and takes about 200 mA with a good signal strength and 2 clients connected.
- JasonNMay 21, 2018NETGEAR Employee Retired
Hi ordos18,
I'm glad you were able to find a work around for you issue. :]
For USB voltages, I would suggest calling the NETGEAR support line.
- Jason N
