SOliver
Jun 10, 2021Follower
AirCard 790 does not worke since the last update...
Since the last update my AirCard 790 does not work anymore. It tries to start approximately 10 times while it shows the typical start screen "NETGEAR AirCard" that I know from normal operation. After...
Blanca_O
Sep 01, 2021NETGEAR Employee Retired
Hi SOliver,
Welcome to NETGEAR Community!
Kindly remove the battery and SIM card, wait for a minute or two then re-insert the SIM card and battery. Then check if it will completely start up the device.
Blanca
Community Team
- bettyboop99Oct 26, 2021Aspirant
screen locked on the purple startup blue light on and will not change
