giakov
Mar 27, 2021Follower
AirCard 797 Mobile Hotspot
Dear all, I have bought an Aircard 797 with a LTE sim for setting up a remote mesuring system and accessing trough the web. The instrument is a Fluke 1748(power meter) who is connected to the hot spo...
- Mar 28, 2021
Hi giakov ,
Depending on your ISP you may not have a real public IP address assigned when connecting via LTE. Most ISP's will issue a NAT'd IP address. I would suggest contacting your ISP to confirm if this is the case first. For port forwarding to work, the WAN IP address assigned to your AC797 must be a real public IP not NAT'd.
ArodiD
ArodiD
Mar 28, 2021NETGEAR Expert
Hi giakov ,
ArodiD
