MRIGGS
Nov 12, 2020Follower
AirCard 797S Connectivity Issue
Hi, hoping someone out there can help with this issue.
I bought an AirCard 797S about 4 months ago. It set up fine and has been used several times without issue since. A few days ago all of a sudden I have no outside connection.
I can connect to the hotspot network without issue, just cannot reach any outside page. The display and the router login indicates LTE signal and have no indication of issues. I use the same network on another device working properly so it's not the carrier or local cell towers.
I've rebooted, checked for updates, pulled and re-seated the sim, cleaned the sim, etc. Even did a factory reset and completely re-set up the device by hand with no luck.
At this point I'm considering sending the device back but just wanted to make sure there's nothing simple I haven't done first.
Thanks
1 Reply
- CathyBkindAspirantGood luck returning your AirCard 797. There is only a three month warranty.
