Txabola
Dec 04, 2022Follower
AirCard 810 without SIM. How to conect to the public wifi of a hotel
I would like to connect my Aircard 810 to the public WIFI of a hotel There is not a SIM card instaled in my Aircard 810 Please, advice. Your instructions will be very welcom
michaelkenward
Dec 04, 2022Guru - Experienced User
Sounds like you want to use it as a wifi "bridge" repeater.
If this device can do that, the instructions will be in the manual.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Out of interest, why do you want to do this? Can't you simply connect devices to the public wifi?
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Mobile Routers, Hotspots & Modems
Those things are very different from the standard Netgear routers covered in this section.
I will ask the Netgear moderator to move your message.
