YipYip
Sep 23, 2016Follower
AirCard 810S backup link for Network
Community
Can I confirm that I can use a Ethernet Antena & Charging cradle that has a ETHERNET port with the Aircard 810S
As a backup link to the internet for my Network.
I.E Will it provide a WAN IP that i can bridge to my Firewall ? Or Are you stuck with only NAT & Port forwarding ?
Many Thanks in Advance
Justin
1 Reply
- DarrenMSr. NETGEAR Moderator
Hello YipYip
Here is the support page for that dock you should be able to find all the info you need about it.
https://www.netgear.com/support/product/DC113A.aspx?cid=wmt_netgear_organic
DarrenM
