Xenoide
Jun 20, 2019Initiate
AirCard 810S bug: manual network selection mode not working
There is a bug in all firmwares for the Aircard 810S, including the current NTG9X40C_11.14.08.36 If you login to the configuration website via http://netgear.aircard and there try to manually ...
Blanca_O
Sep 04, 2019NETGEAR Employee Retired
Hi Frederic_MUC
Can you post a sample screenshot?
What is the current firmware version?
Network / SIM card used?
Blanca
Community Team
- XenoideSep 05, 2019Initiate
Hi Blanca_O,
if you don't mind, I would like also to post a screenshot of that problem on my device:
It was taken off the web interface on the AirCard, after clicking the Submit button.
Please note, that there is no option to change Network Selection Mode to anything but Automatic.
As stated originally, the firmware version ist NTG9X40C_11.14.08.36 and the SIM card is a Vodafone LTE enabled card of the latest generation.
- Frederic_MUCSep 05, 2019Aspirant
Hi Blanca,
the firmware version of my device is NTG9X40C_11.14.08.36
I am using a LTE enabled Vodafone Germany Simcard. But I have also tried it with other Simcards. The result remains the same.
Best regards
Frederic
- Frederic_MUCNov 16, 2019AspirantSo as usual no answer from these idiots from the Netgear support
