Xenoide
Jun 20, 2019Initiate
AirCard 810S bug: manual network selection mode not working
There is a bug in all firmwares for the Aircard 810S, including the current NTG9X40C_11.14.08.36 If you login to the configuration website via http://netgear.aircard and there try to manually ...
Blanca_O
Sep 04, 2019NETGEAR Employee Retired
Hi Frederic_MUC
Can you post a sample screenshot?
What is the current firmware version?
Network / SIM card used?
Blanca
Community Team
Xenoide
Sep 05, 2019Initiate
Hi Blanca_O,
if you don't mind, I would like also to post a screenshot of that problem on my device:
It was taken off the web interface on the AirCard, after clicking the Submit button.
Please note, that there is no option to change Network Selection Mode to anything but Automatic.
As stated originally, the firmware version ist NTG9X40C_11.14.08.36 and the SIM card is a Vodafone LTE enabled card of the latest generation.
