Xenoide
Jun 20, 2019Initiate
AirCard 810S bug: manual network selection mode not working
There is a bug in all firmwares for the Aircard 810S, including the current NTG9X40C_11.14.08.36 If you login to the configuration website via http://netgear.aircard and there try to manually ...
Blanca_O
Sep 04, 2019NETGEAR Employee Retired
Hi Frederic_MUC
Can you post a sample screenshot?
What is the current firmware version?
Network / SIM card used?
Blanca
Community Team
Frederic_MUC
Sep 05, 2019Aspirant
Hi Blanca,
the firmware version of my device is NTG9X40C_11.14.08.36
I am using a LTE enabled Vodafone Germany Simcard. But I have also tried it with other Simcards. The result remains the same.
Best regards
Frederic
- Frederic_MUCNov 16, 2019AspirantSo as usual no answer from these idiots from the Netgear support
