Xenoide
Jun 20, 2019Initiate
AirCard 810S bug: manual network selection mode not working
There is a bug in all firmwares for the Aircard 810S, including the current NTG9X40C_11.14.08.36 If you login to the configuration website via http://netgear.aircard and there try to manually ...
Frederic_MUC
Sep 05, 2019Aspirant
Hi Blanca,
the firmware version of my device is NTG9X40C_11.14.08.36
I am using a LTE enabled Vodafone Germany Simcard. But I have also tried it with other Simcards. The result remains the same.
Best regards
Frederic
Frederic_MUC
Nov 16, 2019Aspirant
So as usual no answer from these idiots from the Netgear support
