jlm70
Mar 02, 2018Aspirant
Aircard 810S Firmware Update NTG9X40C_11.14.08.32
Does anybody know what kind of updates does the new (2018/01/23) AirCard 810S firmware update bring to the router? I've upgraded it via network, on router request, but... I do not like doing updates...
JasonN
Mar 06, 2018NETGEAR Employee Retired
Hi SkimMilk,
Can you take out the SIM card and reseat it into the SIM card slot. Make sure it is seated properly and let it power all the way on then check for updates.
Please let me know if that helps. :]
- Jason N
- SkimMilkMar 06, 2018Aspirant
Thanks for the suggestion Jason. Tried it, no updates available.
Thought it could be an APN issue so I switched it back to Telstra's APN and rebooted, same thing, no updates available.
For both scenarios, data network is working as I could surf the net.
Just couldn't find any updates available.
