SC777
Sep 18, 2016Follower
AirCard 810s firmware update
Is anybody aware of a firmware update for the AirCard 810s? If so please provide a link.
Gary_Y
Mar 02, 2017NETGEAR Employee Retired
Hi SC777,
Easiest way is to check for a firmware update Over the Air.
For the Telstra AirCard 810S - the last Maintenance Release was available from Oct 10, 2016 and is for firmware C11.14.8.12. You can check by going into the device screen Touch UI and Settings and Check for Updates. You can also see what is your current firmware version in Settings and if it is the same as mentioned here - then you are running the latest firmware.
Why are you after a firmware upgrade? Is there something you are after?
Thanks.
Gary
