SC777
Sep 18, 2016Follower
AirCard 810s firmware update
Is anybody aware of a firmware update for the AirCard 810s? If so please provide a link.
Gary_Y
Mar 02, 2017NETGEAR Employee Retired
Hi SC777,
Easiest way is to check for a firmware update Over the Air.
For the Telstra AirCard 810S - the last Maintenance Release was available from Oct 10, 2016 and is for firmware C11.14.8.12. You can check by going into the device screen Touch UI and Settings and Check for Updates. You can also see what is your current firmware version in Settings and if it is the same as mentioned here - then you are running the latest firmware.
Why are you after a firmware upgrade? Is there something you are after?
Thanks.
Gary
relume
Mar 14, 2017Guide
Hello
I am looking also for an firmware update for AirCard 810S 100EUS. On my new modell (bougth march 2017) is installed fw NTG9X40C_11.14.07.00 but no new fw is showing up or is downloadable. There is serious issue about the compatibility with car-adaptor chargers (see: https://community.netgear.com/t5/AirCard-LTE-Hotspots-Gateways/810s-in-vehicle-charging/m-p/1179288/highlight/false#M1445). In that forum thread there is said about a bug that should be addressed in a firmware update.
Many thanks
- steveswMar 14, 2017NETGEAR Expert
There is a firmware update planned for Mar 20 on the AC810-100EUS that should allow the device to charge with a wide range of chargers.
Steve
- relumeMar 21, 2017Guide
Hello Steve
Is there any news about the firmware update for the AirCard AC810-EUS? As I am using the AirCard only with a SIM-card for a foreign country, I am not able to check any automatic firmware updates over mobile internet connection. At this moment I could not find (german netgear support site) any downloadable update file in order to update the AirCard by a browser uploadable file.
Many thanks in advance
for other readers see this forum thread https://community.netgear.com/t5/AirCard-LTE-Hotspots-Gateways/Netgear-810-update/td-p/1200773/page/6 ...
