chriswal
Aug 18, 2017Aspirant
Aircard 810s Retail new Firmware 23112817
Hi, Today i got a new firmware version 23112817 OTA for my Aircard 810s. Dont need to load different drivers to get it working ..its running with the standard drivers ..on Windows 10 runs without...
chriswal
sorry the version is NTG9X40C_11.14.08.26
chriswal
Aug 19, 2017Aspirant
It was to early to be happy.. after some time the programs using the internet connections got locked up ..and locked up again the whole system ..after changing to USB RNDIS6 Drivers it works again ...so not solved with the new Firmware
And the Device works in thethering mode without battery only if you disable wifi ..if there is a wifi device transmitting data the device resets ..
