dod_88
Nov 28, 2016Follower
Aircard 810s
Hi I have some questions about the 810s i bought. The main features works fine. But there are some points i don't get... 1. Can you hide the password from the Device? You can hide it from...
DarrenM
Dec 01, 2016Sr. NETGEAR Moderator
Hello dod_88
1. I do not see a way to hide that.
2.It should be off when you disable that I will have to look into that issue
3. I see no options to turn off SMS
DarrenM
