n_brumley
Aug 27, 2019Follower
Aircard 810S
I am looking at buying the Aircard 810S in Australia unlocked and want to use it in Australia and Europe, particularly Italy and Greece. Are there any issues using the 810S in Italy or Greece on loca...
Blanca_O
Sep 03, 2019NETGEAR Employee Retired
Hi n_brumley
Welcome to NETGEAR Community!
If your device is unlocked then you should be able to use it. Please check the list of the supported bands and if the bands are supported by your Internet Service Provider (ISP).
Kindly visit the following links:
https://kb.netgear.com/29947/List-of-Carriers-Supported-by-AirCard-Hotspot
Blanca
Community Team
