PerSund
Feb 10, 2025Aspirant
Aircard 810s
Hi, Have used Aircard 810s for a long time. Suddenly it refuses to recognise the SIM card (Swedish operator). Have used the same SIM for 2-3 years. Have changed SIM to another that I know works. H...
PerSund
Ahhh,
The Aircard sys, ”No SIM card” or something similar.
rcpax
Feb 10, 2025Luminary
PerSund wrote:
Ahhh,
have you tried the non-working SIM on another working device such as a cellphone? and does it work? If it does work on a cellphone, it could very well be your Aircard 810.
You also said you have put a known working SIM card in there. What happened, does it still not recognize it?
- PerSundFeb 11, 2025Aspirant
It is a known functional SIM that I have put there. Took it from another Mobile Hotspot that I have.
The response is still, type off, "No SIM-card installed."I believe that it is the 810S and the SIM-card recognition functionality.
Have resettled the 810S. It says that it is the latest firmware.
Never heard of that the SIM-card compartment stopped working like that.- rcpaxFeb 11, 2025Luminary
By resetted you mean full factory reset? Because that's what I suggest next. Do a full factory reset. You also mentioned it's on the latest firmware. If that fails, do a physical cleaning of the contacts of the SIM connector. Usually just 70% isopropyl alcohol and some cloth or cotton buds, just moist enough, not dripping wet. see if that helps. clean your sim card contact pads as well. if that fails still, it could be a component failure in the board, which at that point, it's beyond repair on your end. let us know how it works out. I'm hoping it's just a poor contact on the SIM tray.
