ems18432's avatar
ems18432
Aircard 815s light flashes between blue and orange continually
The Light on my AirCard 815s is flashing between blue and orange at all times. I had stopped using this for a while. It was working perfect when I quit using it and when I tried to reconnect this was all I had. Anyone have a clue what could be causing this
  • plemans's avatar
    Are you talking the status led?
    here's what they mean:
    • Blue, slow blink. The mobile hotspot is ready.
    •  Blue, double-blink. The mobile hotspot is transferring data.
    •  Amber, slow blink. The mobile hotspot is not connected to the network.
    • ems18432's avatar
      ems18432
      The status light is alternating between blue and orange rapidly continually
  • JohnPeng's avatar
    JohnPeng
    NETGEAR Expert
    Is the device still working and you can get the data connection with it? If not, please check your SIM card and plan.
    Thanks
