danyelerm10
Nov 25, 2015Aspirant
AirCard ac785-100eus problem for xbox one nat open
hello i have a problem between my Xbox console and one modem netgear aircard ac785-100eus which is the exact procedure for the nat open on my console? the operation that I made are these: I set a...
danyelerm10
Mar 13, 2016Aspirant
does anyone know how to solve the problem? Thanks
- DarrenMMar 18, 2016Sr. NETGEAR Moderator
Hello Danyelerm10
When you reboot the xbox is it changing ip address that could be the issue. The ac785 does not have a address reservation feature so check to see if its jumping IP address.
DarrenM
