danyelerm10
Nov 25, 2015Aspirant
AirCard ac785-100eus problem for xbox one nat open
hello i have a problem between my Xbox console and one modem netgear aircard ac785-100eus which is the exact procedure for the nat open on my console? the operation that I made are these: I set a...
danyelerm10
Mar 13, 2016Aspirant
does anyone know how to solve the problem? Thanks
DarrenM
Mar 18, 2016Sr. NETGEAR Moderator
Hello Danyelerm10
When you reboot the xbox is it changing ip address that could be the issue. The ac785 does not have a address reservation feature so check to see if its jumping IP address.
DarrenM
