archspangler
Oct 01, 2016Star
Aircard U340 not working on Apple MacOS Sierra
I upgraded my MacBook Pro to Apple Sierra macOS 10.12 and I can no longer use my 340U device. I have tried the AT&T All Access connection manager and also the Netgear Watcher software. Both of the ...
- Oct 15, 2016
EUREKA!
New driver has been made available on 10/24/2016.
Welcome.
http://kb.netgear.com/app/answers/detail/a_id/26983/(Opens%20in%20new%20window)~/aircard-340u-(at%26t-beam)-downloads-and-documentation?cid=wmt_netgear_organic
egberts
Oct 14, 2016Guide
Executing the equivalent of lsusb command which is system_profiler SPUSBDataType shows:
USB 3.0 Bus:
Host Controller Driver: AppleUSBXHCIPPT
PCI Device ID: 0x1e31
PCI Revision ID: 0x0004
PCI Vendor ID: 0x8086
AirCard 340U:
Product ID: 0x9051
Vendor ID: 0x1199 (Sierra Wireless Inc.)
Version: 0.06
Serial Number: 013323002244540
Speed: Up to 480 Mb/sec
Manufacturer: Sierra Wireless, Incorporated
Location ID: 0x14100000 / 2
Current Available (mA): 500
Current Required (mA): 500
Extra Operating Current (mA): 0
egberts
Oct 14, 2016Guide
Looks like the El Capitan driver doesn't work for the Sierra (10.12) release anymore.
- archspanglerOct 15, 2016Star
Here is what I see from System Information
AirCard 340U:
Product ID: 0x0fff
Version: 0.06
Serial Number: 013323002368315
Location ID: 0x14200000 / 8
WWAN Information:
AirCard_340U:
Device Version Number: 6
idProduct: 0x9051
idVendor: 0x1199
locationID: 0x14200000 @ 0
- egbertsOct 15, 2016Guide
Your cut-n-paste is missing the last line of the WWAN output, titled "Modem software: Unknown" as it did for me.
I'm going to assume that you are running El Capitan (10.11) version. If so, thank you.- egbertsOct 15, 2016Guide
For those who know, the driver in question is downloaded from NetGear and is called AirWatch v2.5.0.
In my case, I am using AT&T mobile broadband provider, and use the following driver from: https://www.att.com/devicehowto/tutorial.html#!/stepbystep/id/stepbystep_KB421838?make=ATT&model=BeamAC340U
