MassimoG's avatar
MassimoG
AirCard785S - Speed and connection torubles
Hello,
I bought an AC785S on Amazon and I am having big troubles about speed and connection!
I have a TIM connection at 42,2 speed SIM and I have never had problems about it before: I used the SIM in a Huawei router made custom for this SIM.
Now using the AC785S everytime I connect at first it has no problems apparently but after a couple of minutes the connection becomes slower and slower (on Twitter it starts not loading images, i.e.) and after a couple of minutes later it stops and sometimes my iPad even says there is no connection!
I have tried the SIM inthe old router and it works well it seems not beeing a problem about line.
As I bought the router I updated the firmware and as I put the SIMin the router started to set the values so everything seemed ok but it's not.
What can I do?
I have tried to:
  1. change DNS using the OpenDNS
  2. setting the wifi dual band
  3. restore settings
but no results till now.
What can I do? How can I set the router properly? I thought AirCard was able to set itself automatically...
Thanks for Your kind attention.
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello MassimoG
    Is the Sim card a Telstra sim card or is it another provider?
    DarrenM
    • MassimoG's avatar
      MassimoG
      Hello!
      I live in Italy so there is not Telstra here.
      My provider is TIM and I have to refresh the situation: I called TIM and I explained them my problem so they made a "re-boot" (or something like that) for my SIM and now it seems working well!
      Thanks!
      Massimo
