RObVDN
Nov 26, 2019Aspirant
ALDI mobile Netgear setting
I have a Netgear MR1100 mobile router which has been using a Telstra SIM. I decided to change to ALDI since the unit is nolonger locked to Telstra and the packages are cheaper. However, I have been u...
Blanca_O
Dec 01, 2019NETGEAR Employee Retired
Hi RObVDN
Welcome to NETGEAR Community!
Does it say "SIM Not Installed"? If so, ensure that the micro SIM card is installed correctly. Please check this reference: http://www.downloads.netgear.com/files/GDC/MR1100/MR1100_UM_EN.pdf [page 12]
If no error message pertaining the SIM card, you may need to create a new profile using carriers APN and profile information. Here's a reference: http://www.downloads.netgear.com/files/GDC/MR1100/MR1100_UM_EN.pdf [page 33 - 35]
Blanca
Community Team
RObVDN
Dec 02, 2019Aspirant
Thanks Blanca.
I have not got any "SIM Not Installed" issues and I have also created the APN for the Aldi SIM as per their instructions but, for some reason, it is not recognising or detecting the SIM card. I am working through this with the Aldi Technical Support people as well but have not yet resolved the problem. If you have any other thoughts please let me know. If I resolve my problems through Aldi Techniccal Sapport, I will also advise you of the resolution.
Thanks and regards,
Rob
