Jeff1107's avatar
Jeff1107
Follower
Jan 12, 2020
Amber Light on a LB2120 power on won’t connect
I have 2 of these in my house. On 1 all lights normal. 3 bars of signal. Both hooked to outdoor antenna. The other has amber light no bars and shows not connected. I have reset, powered down and back up, removed the sim and put back in original device and then moved back to the 4 G modem but still the same solid amber light. Any ideas?
1 Reply
  • We have been using one for a year with Cricket no problems......it stopped working and now Cricket and AT&T say it will no longer work on their system.
