ChrisHarding
Nov 23, 2021Aspirant
Antenna plugs for Nighthawk M2
Hi Guys We livestream weddings and I have two M2's each with a different carrier as sometimes some cell towers are closer than others. I use a LPDA antenna on a 4m stand in most cases but fing tha...
W1lliam
Nov 24, 2021Virtuoso
On original TS-9 antenna port, once you have any antenna connector plugged, the built-in antenna will be disconnected regardless if you have external antenna plugged along with that connector.
ChrisHarding
Nov 24, 2021Aspirant
Thanks so much William
Darn! I was hoping the unit wouldn't see the the adapter as it's just an open circuit device with nothing plugged into it but obviously not ..I have actually used epoxy to keep the TS9-SMA adapters in place so instead of trying to chip the adhesive away would it be a better bet to just screw in two SMA 4G antennas into the adapters if I don't want to use my big LPDA antenna (like in an indoor environment) Your help is much appreciated!!
