rvtips
Jan 23, 2021Tutor
antenna why two
Why do you need two antennas ? I have a Wilson trucker antenna can I use it on one of the conntector on the nighthawk? Phil
Jan 25, 2021Guru - Experienced User
rvtips wrote:Why do you need two antennas ?
Phil
For what router?
tough to say with minimal info.
But I will say, a CB antenna uses a different wavelength than 2.4ghz, 5ghz, or cellular signal.
- rvtipsJan 25, 2021Tutor
The Wilson trucker anntena is for a cell phone.
