JT240Z
Jun 12, 2023Luminary
Any known issues with the new MR6150 or the MR6550?
I'm looking at taking the plunge with the M6 hotspots but am concerned with all of the issues related to the AT&T version MR6500. Does anyone know of any of the same issues (Overheating, dropping se...
- Jul 09, 2023
Good update. Let us know how it works over the long haul.
Jun 12, 2023Guru - Experienced User
I've go the MR6150. all my updates have been pushed to it. Netgear sends the updates to ATT (mine's locked to att) and from there I get the updates. Not sure exactly how it works with unlocked units.
JT240Z
I thought that all MR6150's are unlocked for use on any system. How is yours "locked" to AT&T? Can't you put in a T-Mobile SIM card and use their system?
