alanhouser
Jan 11, 2015Tutor
Any Secret to using an external antenna with the LG6100D?
Hello. I'm thrilled to have a shiny-new Netgear LTE Gateway LG6100D from Sprint, or I was until I cannot get it to work with an external antenna system. I bought a 50' LMR-400 cable and an adapto...
alanhouser
Jan 12, 2015Tutor
Problems fixed! (at-least for my situation)
In troubleshooting, I noticed my network channel was locked at 41. I called Sprint, got my MSL number and deleted channel 41. Now I'm on 25 with full bars! I guess 41 wouldn't go through our walls. (Same issue on Zing and the 6100!)
—Why Sprint support wouldn't help with this, I have no idea.
As for the issue with the antenna not working, I'm pretty certain the jumper-cable inside the 6100 (from the board to the antenna) has gotten disconnected. Guess I'll only know if I can void the warranty.
gkarasik
Feb 13, 2016Guide
Hi,
Please can you provide more detail about "deleting" Channel 41? I've been inside the GUI and can see where I can change to a different channel, but I don't see where I can delete the channel assignment altogether.
GaryK
- vsppMar 17, 2016Guide
Settings, Network, Setup, Advanced Settings, Get MSL# from Sprint and enter, uncheck 41box, Submit.
