alanhouser
Jan 11, 2015Tutor
Any Secret to using an external antenna with the LG6100D?
Hello. I'm thrilled to have a shiny-new Netgear LTE Gateway LG6100D from Sprint, or I was until I cannot get it to work with an external antenna system. I bought a 50' LMR-400 cable and an adapto...
DonUp0
Mar 24, 2015Novice
I have a Netgear Gateway 6100D. Does anyone know why the device would show a much higher data usage than actual? The Sprint website shows a little less than 7 GB, normal for about 2/3 of the way through the month, but the Gateway shows 394.6 GB split about equally between 3G and 4G data. This is only the second month that I've had it and it was the same way the first time, indicating hundreds of GBs of usage over my limit. It doesn't affect my account, Sprint bills on what is shown on the website, but that feature of the router is worthless. Any advice would be appreciated.
