MicW
Mar 13, 2018Luminary
Anyone know what the latest firmware for the M1100 fixs?
As the title says, I just checked and noticed a new firmware is available. Does anyone know what it fixs / changes ?
- Mar 13, 2018
104 Mb, v NTGN9X50C_10.25.01.01
There's a neat new setting under Setup|Mobile Routing for Ethernet Standby which I have disabled and testing is going well through WAN Connection to Dovado which until now I had to use with Wifi spotboost.
MR1100 seems to run a bit hotter. I have been using without battery since last fw upgrade, up to 10 days without reboot. Currently at 4 hours and counting, with no dropouts and speeds greatly improved.
Dashboard has lost data usage info, hope to see it return. No info on Telstra Community and Netgear UM is still for June 2017.
UK-based
MicW- what's the number of the firmware you're referring to?
That's why I started this thread a while ago, but I've had no response from Netgear staff yet.
MicW
Uk-based
It is the 104 Mb, v NTGN9X50C_10.25.01.01 as hippolyte wrote.
I haven't installed it yet as I run my M1 without the battery.
I'll install it tonight , the dashboard usage data has never displayed for me, but I don't use Telstra. I'm guessing that is a Telstra tie in. I'm interested to see if it does provide a speed improvement.
Thank you everyone for the helpful posts .
