MicW
Mar 13, 2018Luminary
Anyone know what the latest firmware for the M1100 fixs?
As the title says, I just checked and noticed a new firmware is available. Does anyone know what it fixs / changes ?
- Mar 13, 2018
104 Mb, v NTGN9X50C_10.25.01.01
There's a neat new setting under Setup|Mobile Routing for Ethernet Standby which I have disabled and testing is going well through WAN Connection to Dovado which until now I had to use with Wifi spotboost.
MR1100 seems to run a bit hotter. I have been using without battery since last fw upgrade, up to 10 days without reboot. Currently at 4 hours and counting, with no dropouts and speeds greatly improved.
Dashboard has lost data usage info, hope to see it return. No info on Telstra Community and Netgear UM is still for June 2017.
TeeJay74
Mar 25, 2018Virtuoso
Firmware updates should come available as soon as they are approved. QA testing takes time and if there uncertainties it is probably wise to postpone firmware availability. So there might be a good reason if no update is available(something is not ready yet).
rabbieb
Mar 25, 2018Guide
That's understood. The firmware update came via the official channel of my telco Telstra. I did the update. It caused multiple issues. I suspect file errors. Telstra made it available thru the device's webpage so there's no file for me tore-install. Telstra insists Netgear is responsible for hardware updates. But Netgear says there is no firmware available for the device. See my problem?
- TeeJay74Mar 25, 2018Virtuoso
Hi,
What is your current FW version number ? That new version you are waiting for, do you know its version number ?
