MicW
Mar 13, 2018Luminary
Anyone know what the latest firmware for the M1100 fixs?
As the title says, I just checked and noticed a new firmware is available. Does anyone know what it fixs / changes ?
- Mar 13, 2018
104 Mb, v NTGN9X50C_10.25.01.01
There's a neat new setting under Setup|Mobile Routing for Ethernet Standby which I have disabled and testing is going well through WAN Connection to Dovado which until now I had to use with Wifi spotboost.
MR1100 seems to run a bit hotter. I have been using without battery since last fw upgrade, up to 10 days without reboot. Currently at 4 hours and counting, with no dropouts and speeds greatly improved.
Dashboard has lost data usage info, hope to see it return. No info on Telstra Community and Netgear UM is still for June 2017.
rabbieb
Mar 26, 2018Guide
Yes my M1 shows PRI is 3.21 and FW is NTG9X50C_10.25.01.00.
"Each firmware released to us about 6 weeks after build dates, presumably for provider testing."
Does this mean Netgear will make it generally available in a few weeks?
JasonN
Mar 27, 2018NETGEAR Employee Retired
Hi everyone,
I am going to forward this issue to my internal team to have them look into this issue. I will update everyone when I have more information. :]
- Jason N
- hippolyteApr 08, 2018Apprentice
Hello All,
Please see latest offer of support from Telsta: Nighthawk-M1-Firmware-Update-Protocols
Any advice on whether I should proceed with device replacement. Unable to get to Tech Bar to see it working before I commit. Quandary.
