MicW
Mar 13, 2018Luminary
Anyone know what the latest firmware for the M1100 fixs?
As the title says, I just checked and noticed a new firmware is available. Does anyone know what it fixs / changes ?
- Mar 13, 2018
104 Mb, v NTGN9X50C_10.25.01.01
There's a neat new setting under Setup|Mobile Routing for Ethernet Standby which I have disabled and testing is going well through WAN Connection to Dovado which until now I had to use with Wifi spotboost.
MR1100 seems to run a bit hotter. I have been using without battery since last fw upgrade, up to 10 days without reboot. Currently at 4 hours and counting, with no dropouts and speeds greatly improved.
Dashboard has lost data usage info, hope to see it return. No info on Telstra Community and Netgear UM is still for June 2017.
MicW
Apr 17, 2018Luminary
My modem just reported a new firmware is available. Fingers crossed I'll report back once its installed and let you know what version it is,
MicW
The new firmware jsut released is version NTG9X50C_10.25.01.01, note the extra .01 so I'm guessing it is a minor bug fix. Pri version is 3.22
- MicWApr 17, 2018Luminary
No noticeable changes. Everything so far seems to work on a non telstra sim. RS-SINR still displaying 0 dbm, but that is a minor thing. I'm assuming this is the fix for the telstra display, I guess hippolyte will let us know soon if it is working if he upgrades his first M1. And hopefully everyone affected by the bug that prevented firmware updates is fixed now too.
