MicW
Mar 13, 2018Luminary
Anyone know what the latest firmware for the M1100 fixs?
As the title says, I just checked and noticed a new firmware is available. Does anyone know what it fixs / changes ?
- Mar 13, 2018
104 Mb, v NTGN9X50C_10.25.01.01
There's a neat new setting under Setup|Mobile Routing for Ethernet Standby which I have disabled and testing is going well through WAN Connection to Dovado which until now I had to use with Wifi spotboost.
MR1100 seems to run a bit hotter. I have been using without battery since last fw upgrade, up to 10 days without reboot. Currently at 4 hours and counting, with no dropouts and speeds greatly improved.
Dashboard has lost data usage info, hope to see it return. No info on Telstra Community and Netgear UM is still for June 2017.
MAGADE
Apr 11, 2018Guide
I guy, first sory for my english but it is not my native language.
May somebody can explain to me the process of the OTA update.
I got a AUS version with very old firmware but doesn't want to update
It is an unlocked TELSTRA and used with a french free sim.
It work but it is impossible to get an update.
What mean repeat OTA. It is a synchronisation with a server who check if the product have asked before to update over the OTA with the EMEI number or other stuf like that?
It it possible to ask to netgear to clear my remote acces for my product to reinitialized my update OTA process?
Please, explain to me. Thanks
JasonN
Apr 17, 2018NETGEAR Employee Retired
Hi hippolyte,
Please let us know when you have updated. :]
- Jason N
- hippolyteApr 17, 2018Apprentice
Update applied successfully:
Screen with data usage immediately restored.
Correctly showing 2 devices connected; one WiFi - one Ethernet on screen and in dashboard.
No factory reset performed by me. Whitelist and LTE settings still intact but curiously Ethernet setting had reverted to Standby 2 mins. Changed without reboot.
As for MicW, no other noticeable differences.
Download 104MB, will the other device on NTG9X50C_10.16.04.04 go straight to NTG9X50C_10.25.01.01? OTA is relatively new to me.
Thanks Netgear for restoring the colourful screen I have come to like.
