MicW
Mar 13, 2018Luminary
Anyone know what the latest firmware for the M1100 fixs?
As the title says, I just checked and noticed a new firmware is available. Does anyone know what it fixs / changes ?
- Mar 13, 2018
104 Mb, v NTGN9X50C_10.25.01.01
There's a neat new setting under Setup|Mobile Routing for Ethernet Standby which I have disabled and testing is going well through WAN Connection to Dovado which until now I had to use with Wifi spotboost.
MR1100 seems to run a bit hotter. I have been using without battery since last fw upgrade, up to 10 days without reboot. Currently at 4 hours and counting, with no dropouts and speeds greatly improved.
Dashboard has lost data usage info, hope to see it return. No info on Telstra Community and Netgear UM is still for June 2017.
JasonN
Apr 18, 2018NETGEAR Employee Retired
Hi hippolyte,
Thank you for the reply! I'm glad that the update has fixed the issue for both of your devices. :]
- Jason N
KarmusDK
Apr 19, 2018Apprentice
Hi.
When will you release a new firmware for MR1100-100EUS? I just wonder why the firmware page under download center in support is empty.
