Tmaciasm
Apr 23, 2023Initiate
APN 1028 error on MR6500
Please define and supply the fix on APN 1028 error
dalereif
Jul 03, 2023Aspirant
07-03-2023
I am getting same error on a new MR6500 Pro. The request to confirm APN data is absurd on a new device. How am I as a consumer supposed to know that and it was working anyway. We are now rebooting the device every 30 minutes so I can work while away from home. Also, no where can I find what a 1028 error means. Short of going to a local AT&T store how do I fix this expensive "brick"? I posted information yesterday but now response. Firmware is current as of 06-17-23; environment is remote work from an RV. FYI; this device gets very warm (49 deg C) when working which seems unusual.
So what now?
- JohnPengJul 03, 2023NETGEAR Expert
Could you please confirm whether you see the error code temporarily or it happens always and the data connection can never be set up?
Please capture a model.json file and send to my email jopeng@netgear.com.
- Logon to the webui (http://192.168.1.1 ) as an administrator (Must log in as admin first)
- Navigate to URL http://192.168.1.1/model.json via the same browser window
- Capture the results (by selecting all + copy) and send it back
dalereif wrote:
07-03-2023
So what now?
- RashenfelterJul 06, 2023Tutor
Did this get a solution? Mine is brand new and has done this twice in 14 hours.
The device locks up at this point and even though the APN is correct (broadband using AT&T) it will not reconnect without a reboot. I'm also wondering if everyone with this issue is using AT&T?
Today I had yet another lockup, this time showing error 512.
