Tmaciasm
Apr 23, 2023Initiate
APN 1028 error on MR6500
Please define and supply the fix on APN 1028 error
dalereif
Jul 03, 2023Aspirant
07-03-2023
I am getting same error on a new MR6500 Pro. The request to confirm APN data is absurd on a new device. How am I as a consumer supposed to know that and it was working anyway. We are now rebooting the device every 30 minutes so I can work while away from home. Also, no where can I find what a 1028 error means. Short of going to a local AT&T store how do I fix this expensive "brick"? I posted information yesterday but now response. Firmware is current as of 06-17-23; environment is remote work from an RV. FYI; this device gets very warm (49 deg C) when working which seems unusual.
So what now?
JohnPeng
Jul 03, 2023NETGEAR Expert
Could you please confirm whether you see the error code temporarily or it happens always and the data connection can never be set up?
Please capture a model.json file and send to my email jopeng@netgear.com.
- Logon to the webui (http://192.168.1.1 ) as an administrator (Must log in as admin first)
- Navigate to URL http://192.168.1.1/model.json via the same browser window
- Capture the results (by selecting all + copy) and send it back
dalereif wrote:
07-03-2023
So what now?
- RashenfelterJul 06, 2023Tutor
Did this get a solution? Mine is brand new and has done this twice in 14 hours.
The device locks up at this point and even though the APN is correct (broadband using AT&T) it will not reconnect without a reboot. I'm also wondering if everyone with this issue is using AT&T?
Today I had yet another lockup, this time showing error 512.
- RashenfelterJul 07, 2023Tutor
FYI, I went back to AT&T for a second SIM card and immediately after booting up and while still at the store I got the Error 512.
