Tmaciasm
Apr 23, 2023Initiate
APN 1028 error on MR6500
Please define and supply the fix on APN 1028 error
JT240Z
Jul 07, 2023Luminary
Agreed. Auto Reconnect when able should be applied and automatic. That error message appears to be a system error message and would lead me to think that the device was in error mode. Almost like an unhandled exception error in programming.
JohnPeng
Jul 07, 2023NETGEAR Expert
Thanks for the suggestion. We are investigating the issue. Some error codes returned by the network means the network is not ready for data connection. Usually when this happens, the carrier doesn't allow the device keeps reconnecting. It may stress the network further. We will check how to resolve the issue gracefully.
Regards
John
- Darky28Jul 11, 2023Aspirant
Im in Italy with my brand new Nighthawk M6 Pro...
I get APN 1028 and 512 like all 20-30 minutes and have to reboot the device to reconnect.
So i spend 1000$ on a faulty device that doesnt work? 😞
- JohnPengJul 11, 2023NETGEAR Expert
Could you please advise what carrier you are using in Italy and what is the APN setting?
Thanks
John
Network "voda IT"
Technology: LTE
I use a prepayd german vodafone simcard with unlimited roaming data withun europe.
My sim card works perfect in my tablet, but as soon as i use it inside the nighthawk m6 pro and a few of my family use youtube or netflix it crashes within 15-20 minutes with the 512 or 1028 error requiring me to reboot the device manually
APN Setting is:
Data checked
Roamingdata checked
Band; All (3G+4G+5G)
Network mode : Auto
Network: "voda IT"
APN:
APN Name: Vodafone
APN: web.vodafone.de
PDP: IPV4
PDP Roaming: IPV4
Authentication: PAP
Thanks for the quick reply. If possible, could you please capture a model.json file and email to me: jopeng@netgear.com.
Please mention your community ID for easy tracking.
- Logon to the webui (http://192.168.1.1 ) as an administrator
- Navigate to URL http://192.168.1.1/model.json via the same browser window
- Capture the results (by selecting all + copy) and send it backThanks
John
Hi John
I sent you an email with the model.json of the router.
Hope that helps narrow down the issue
at 21:00 today i started watching a Film on Netflix on my dell laptop and was playing some clash of clans on my mobile phone, Heres the times when the router died with the corresponding errors:
21:15 - Error 512
22:23 - Error 1028
23:28 - Error 1028
23:40 - Error 512So thats pretty much the frequency how often the router crashes 😞
21:15 - Error 512
22:23 - Error 1028
23:28 - Error 1028
I checked the log you provided. You are using MR6450.
We have a new release for the device and I have set you device to upgrade to the release over the air. You can do a manual update check by tapping Settings -> More -> Software Update -> Check for Update button.
The new release fixed an issue that the device can't get on 5G network even though the SIM card and network supports 5G. Please check whether the new release can resolve your issue. If not, please send another model.json file for me to check.
Could you please confirm your SIM card has LTE only subscription?
Thanks
John
H John
Thanks much for the fast reply. I can confirm theres now a new firmware available.
The router just installed the version NTGX65_12.01.31.00
My german vodafone prepayed sim card has indeed 5G already included, but I doubt at the location im doing holidays I'll have 5G antennas.
I just checked the Mobile setting after the firmware update and it seems I indeed received a slightly different configuration for the APN from vodafone.
PDP changed from IPV4 to IPV4V6
On the page Status -> Network i noticed something:
At the Technology section it shows:
4G then 4GPLUS then 4G then 4GPLUS seems to toggle quite a bit but so far the internet connection works.
I will check if with the new Firmware the 512 and 1028 errors will stop and will report back tomorrow in the thread here.
Thanks
Bad luck 😞
I noticed when a lot family members use the router the 512 / 1028 error seems to trigger much faster.
I started a netflix stream on the dell laptop. A netflix stream on the tablet and a plex stream on my mobile phone.. took not long and it crashed with a 1028 error:
- JohnPengJul 12, 2023NETGEAR Expert
Darky28I started a netflix stream on the dell laptop. A netflix stream on the tablet and a plex stream on my mobile phone.. took not long and it crashed with a 1028 error:
Darky28
Here are the details on the 2 error messages. They are related to SIM subscription and network rejects or releases the connection.
512 is PS_NET_DOWN_REASON_ALREADY_IN_TC
This error code is returned when data call is brought down
because traffic channel request got rejected by CM since traffic
channel is already up for voice calls1028 is PS_NET_DOWN_REASON_EMM_DETACHED
Could you please advise the SIM card plan is for data only device? Not sure whether this is also related to roaming agreement between the 2 carriers.
If possible, you can get a cheap pre-paid data plan from the Italian carrier and see whether the device performs differently.
Please also send me another model.json file with the new FW.
Thanks
John
- Darky28Jul 12, 2023Aspirant
Hi John
I have the following plan:
https://www.vodafone.de/freikarten/callya-black
unlimited Data in 4G and 5G networks
phone and sms flat but only within germany
500 minutes phonecalls or SMS to Europe
Europe Roaming inclusive.
This morning i couldnt bear it anymore having to restart the router all 15-30 minutes.
I took out the sim card from the router and put it in my Xiaomi Mi Pad 5 Pro tablet.
I setup a hotspot from my tablet and its running stable full day with multiple Netflix streams youtube streams and online gaming for the whole family.
So its definitely an issue with the router and not the sim-card or the data plan.
The 4 weeks prepayed costs me 80$ for 4 weeks, so you can immagine im not eager to buy and try an italian sim card.
I'll put the SIM card back in the router and mail you the new model.json in a second.
Ok I've just mailed you the new model.json file.
- RashenfelterJul 12, 2023Tutor
Just to let you know about some additional testing I've done and things I noticed. I am in Tennessee and on a data plan.
watching TV at night is fine, and working during the day, basic email, and some low bandwidth web portals all while streaming youtube is fine. But if I hop on a teams call with video or try to share my screen, things that seem to put a load on the device/network is when I get the errors.
just for reference, I am only streaming youtube at 480 resolution to keep the load down and I am getting 2 or 3 bars of signal strength on the device.
